Finished backriveting the stiffeners. Started on the skeleton. Made a rough cut of the 717 spacer and the 716 attach strips—then trimmed per plans. Marked 710 rudder horn for trim line—then added .15 inches for final cut line. This is one part that many builders end up building twice. If cut per the plans, meeting minimum edge distance becomes a problem.
