Steve & Nancy Riffe
Date:  3-25-2010
Manual Reference:  6.1.6
Brief Description:  HS-Riveting 810/814 to Spar
Riveted 810/814 angles to the left spar. Riveted it up real good-too! Put three rivets in holes that were supposed to be left open, and put one rivet in with the shop head facing opposite the others. Arrrrggg! Drilled out the backwards facing rivet and replaced. Then drilled out the other three rivets—no problems, all looks good.
Rear shot of front spar
Front side of front spar
