Brief Description: Added wires to Molex connectors
Part 1--While waiting for the temp to warm up enough to mix some resin, I decided to get the Aeroled wiring taken care of. The Aeroled’s are supplied with some Molex connectors and pins. I started on the R. tip, installed the Aeroled light and fiddled with how I wanted to run the wires. I decided to add a nylon thingy so that I could zip tie the wire bundle. I crimped the pins onto the wires and installed in the Molex connector. I added an additional ground wire which will ground the light body to the end rib. Then I did the same for the L. tip except the wire routing goes thru some nylon clips on the Archer NAV antenna. Crimped on the pins, added an additional ground.
