Finished up most of the wiring (except avionics) to the VP-X. Connected the master switch, avionics master, alternator and start switches. Finished the wiring for the power outlets. I daisy chained the front & rear power outlet so that I had only one wire going to the VP-X and one wire to ground. Marked location for the front power outlet, drilled a pilot hole and opened up the hole with a unibit. Then I installed the front power outlet in the right front corner of the F881 console plate.
