Steve & Nancy Riffe
Date:  8-16-2012
Number of Hours:  1.00
Brief Description:  Grove gear-inventory
Decided to move away from the canopy skirts for now. The skirts need some fiberglass work—my original plan was to do all fiberglass near the end of the build, therefore I moved to working on the gear. Started off by removing the canopy/frame—put this assembly back in the shipping crate for safe keeping. Removed the top front skin followed by the roll bar. Then I flipped the fuse upside down—started to remove the rotisserie, but got a bit ahead of the plans. Need to flip it back and ream the ¼” and 7/16” holes in the WD813 gear weldment. Unpacked the Grove gear and hardware from a very “bulletproof” crate-did a quick inventory. Reamed the holes in the U806 inboard wear plate to 5/16”. The Grove U804 inboard bracket is already drilled to the gear. I slipped the AN6 bolts thru the inboard bracket and the wear plate--very nice fit. I need to pick up a new 7/16” bit tomorrow so that I can drill the wear plate using the inboard bracket as a guide.
Removed roll bar, flipped fuselage
Checked fit of Grove brackets/wear plates
Inboard bracket/wear plate
