For the T-708 end plates and fuel senders, I used socket head screws. I’m not particularly fond of Phillips head screws-especially in areas difficult to reach and glued in with proseal. I ordered the stainless steel socket head screws (p/n 92200A104) and washers (p/n 90107A010) from McMaster-Carr. I also used Cherry Max rivets (CR3213-4-2) to secure the anti-rotation bracket. These blind rivets are quick & easy to install—AND you need some quick & easy because the proseal starts to set up quite quickly. Tonight, Nancy and I moved the left wing back into the cradle. Then, I started with the wiring conduit in the right wing—what fun. I got the easy part done-the part thru the area without the skin. The closed in area-especially the wing walk ribs will be a bit more difficult.
