Steve & Nancy Riffe
RV8
L. Elvator-Finished Leading Edge
L. Elevator-worked the roll on the end section-now it lays flat. Drilled to #30, deburred, dimpled and pop riveted it together. Added the rod end bearings.
L.E. roll is finished!
Installing rod end bearing-Boelube makes it easy
Installed Rod End bearing
RV8 Home
2701
Baffles
173
Cowling
356
F/W Forward
81
210
161
Flying!
468
Instrument Panel
Move
Practice Kit
Prop/Spinner
Shop
Wheel pants,fairings
25
68
Windscreen
Wing Install
43
108
Wing Tip Install
Wing Tip Nav Lights
210
Wiring
90
157
