L.Elevator-Riveted the z braces to the trim plate. Countersunk plate and used NAS1097 rivets on the front holes on each side to avoid interference with the servo. Mounted the servo and attached the trim plate to the elevator. Clamped the trim tab to the elevator in neutral position and cut the actuator rod to fit screwed all the way into each turnbuckle. Hooked up a 9 volt battery and ran the trim up and down—very cool. Need to trim a bit of the elevator for clearance when the rod is extended full length.
