Brief Description: Trim Tab- riblet and prep for primer
Trim Tab—finished the outboard riblet. Took it all apart and used a maroon pad to scuff up the parts. Dimpled all with the 3/32” dimple die-used tank die for the bottom pieces. Still have a couple of holes in the inboard rib that will have to dimpled with the pop rivet dimpler.
