Steve & Nancy Riffe
RV8
L. Elevator/Trim Tab-C/S spars
L. Elevator/Trim Tab—drilled and clecoed the 606 spar to a piece of oak board, then used the countersink in my electric screwdriver to countersink the spar. Repeated the process for the 607 spar. Dimpled the elevator skin for the rear spar.
Drilled & clecoed spar to oak
C/S in the spar
C/S both 606 and 607 spars
RV8 Home
2701
Baffles
173
Cowling
356
F/W Forward
81
210
161
Flying!
468
Instrument Panel
Move
Practice Kit
Prop/Spinner
Shop
Wheel pants,fairings
25
68
Windscreen
Wing Install
43
108
Wing Tip Install
Wing Tip Nav Lights
210
Wiring
90
157
