Steve & Nancy Riffe
RV8
R. Elevator-Drilled Skin
Right elevator-assembled ribs and spar, then clecoed the skeleton to the skin. Used a #30 reamer to drill the elevator horn to the end rib and spar. Then used a #41 reamer to drill the skin to the spar and ribs.
Drilled horn to skeleton
Drilled skin to skeleton
RV8 Home
2701
Baffles
173
Cowling
356
F/W Forward
81
210
161
Flying!
468
Instrument Panel
Move
Practice Kit
Prop/Spinner
Shop
Wheel pants,fairings
25
68
Windscreen
Wing Install
43
108
Wing Tip Install
Wing Tip Nav Lights
210
Wiring
90
157
