Steve & Nancy Riffe
RV8
Elevators-Prepare ribs
Fluted 703 & 704 ribs, clecoed together and match drilled. Clecoed the rib assembly to the 702 spar and match drilled. Did this for both left & right sides. Right side-clecoed 709 root rib to 702 spar and match drilled.
Match drilled 703 & 704 ribs
Match drilled ribs to spar
Match drilled 709 rib to spar
RV8 Home
2701
Baffles
173
Cowling
356
F/W Forward
81
210
161
Flying!
468
Instrument Panel
Move
Practice Kit
Prop/Spinner
Shop
Wheel pants,fairings
25
68
Windscreen
Wing Install
43
108
Wing Tip Install
Wing Tip Nav Lights
210
Wiring
90
157
