Steve & Nancy Riffe
RV8
VS-Nose Rib Riveting
Drilled out rivet in nose rib-came out very nicely. Used long rivet set (8”) and bent the nose rib up slightly to get squarely on rivet. This one came out perfect. Used the pneumatic squeezer on the tip rib to spar. Front spar all complete.
Fuzzy pic??
This one comes out!
Second time worked much better!
RV8 Home
2701
Baffles
173
Cowling
356
F/W Forward
81
210
161
Flying!
468
Instrument Panel
Move
Practice Kit
Prop/Spinner
Shop
Wheel pants,fairings
25
68
Windscreen
Wing Install
43
108
Wing Tip Install
Wing Tip Nav Lights
210
Wiring
90
157
