Brief Description: Rivet Frame Together 6: Side Skins
The side skins go on next. First I had to trim the corner per how I wanted it. I decided the corner floating out in space was a formula for cracking thru the fiberglass later so I trimmed off the forward corner of the side skins. This seems like it makes the skin stiffer in this area and more attached to the side rail without any loose corners. And this will be filled in with fiberglass.
