Brief Description: Trimed canopy interface to window
With the canopy and window installed I examined the gap. It was pretty good, but still required a little sanding at some tight spots. The gap is not totally parallel its entire length. I will cover this with a fiberglass trim stripe latter.
Also I don't like the corner of the canopy coming down near the aft skin. It is going to hit that skin and bend it. I plan to cut these corners off soon.
