Brief Description: Baffle 12 Mark and cut baffles to height.
Decided I needed to trim the top of the baffles off. Suppose to be abou 1/2 inch of clearance. I made 4 4-inch spacers to hold up the top of the cowl. then I stuck a ruller up there along the baffles and made a mark 4 inches down. This should make the baffles just exactly fit.
I cut the material off at the mark and it worked pretty good for a ball park cut.
