This Rear Connector is really complicated and is the largest connector of the bunch. But straight forward. You just have to follow the pin map closely.
Some of the power wires for the landing lights and heated pitot had to be split into two so that voltage is drawn 5 volts max per pin. You can get 10 Volts in the wire to the light, but you have to do it with two 5 volt pins in the connector.
The wires I had used for the landing lights and pitot were about18 gauge so I merely unwound the threads of the wire into two pieces. No cutting. No connectors. Then the D-sub pins would slip on.
