Brief Description: Fwd Fuselage - Landing Gear Mount Fit 2
I used sanding drums to remove material on the flange and bulkhead. Fit try as you go. Then I noticed the weld on the landing gear mount was bumpy and taking up a lot of room. So I filed it down some to. You can see I already sanded pretty close to the rivet hole. So the weld had to be reduced or at least smoothed off.
