Brief Description: Tank Prep - Locate Right Tank 1
I put the right tank on the wing and moved it into position with zero gap between tank skin and leading edge skin. Then I drilled the inboard Z-bracket which firms up the location of the tank on the wing and gaurantees zero gaps.
