Brief Description: Pulled Rivet Gun Modified for Tight Spots
This pulled riveter is for tight clearance. I sanded off the front part. I used the one in the first photo for the Z-brackets on the Fuel Tanks. But it did not have enough pull strength for the Cherrymax rivets that I used to fasten down the leading edge to the spar web. So I bought another rivetor and ground down the front until I had about a 1/4 inch depth and I used this on the Leading Edge to pull the Cherrymax rivets through the LE rib aft flange to the main spar web. Worked good and still works for other things.
