RV-7A Construction Log
Date:  8-6-2008
Number of Hours:  1.00
Brief Description:  Yoke for Hard to Reach Rivets in thin areas
Yep, I spent the money on a 1 1/2 inch no-hole yoke and ground down the no-hole end so that I can reach the -3.5 revits at the trailing edge of the elevators, rudder, etc. It works. It takes a little technique because the yoke still pushes up the rivet slightly but if you squeeze just a little you can then push the rivet in the hole the rest of the way, and make your final squeeze and it comes out flush. YEA! I think I better lend this to my brother, Ed. He likes 'POP" rivets.
1 1/2 inch yoke ground down to about 3/32 width
Fits in the tight trailing edge revits
No POP revits.  YEA!!!
