The aft end of the push rod needs to be centered between the elevator horns. I made to short tube spacers. Each is 3/16 long. Not sure if I'll use these or later just use washers.
The top bolt that connects between the two elevator horns and the bearing on the HS needs washers to take up the space. I found using the washer tools absolutely necessary to get these washers on.
