RV-7A Construction Log
RV-7A
Use Proseal on some gaps
Before getting back to tubing I decided to use some Proseal to secure the edge of the aluminum around the hole I cut for the flap push rod.
While I was at it I put some Proseal around the step gap.
And I noiced some light coming thru around the conical bend so I put Proseal on those gaps also.
It just seems right to seal up some of these gaps.
Proseal on rudder hole
Proseal around step
Proseal on gaps
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
