RV-7A Construction Log
Date:  12-26-2009
Number of Hours:  0.50
Brief Description:  Tubing: Fuel Line 5 (Kinks)
I made four of these also. The first one didn't even get in. The second one had kinks near the valve because I didn't get this part of the tube bent right to fit the valve and when I went to fix it by hand it kinked. So this got replaced and I did a better job bending this area of the tube with the bender which does a smooth job.
Notice kink below valve
See kink by bracket - no good
