Brief Description: Aileron Rigging 3: Adjusting and tightening
After getting the sticks parallel and the ailerons set to neutral it was pretty simple to turn the end bearings on the push rods until they just fit into the sticks.
Then I tightened the nuts up against the push rods. I'll be removing all this later and I don't want any of the distances to change. Pulling the sticks all the way forward makes access to tightening the nuts easy.
