RV-7A Construction Log
RV-7A
Forward Covers 12 Stick Boot Rings
Then I used the nibler to cut out the center material.
I used sanding drums on the drill press to bring the hole dimensions flush with the floor's hole. This took awhile.
Final step was to use the scotch bright wheel to smooth all the edges. This process made my stick boot rings a perfect fit over the floor hole.
Nibled out the center
Sanding drums to bring to finish size
Finally scotch bright to smooth it off
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
