RV-7A Construction Log
RV-7A
Fwd Fuselage - Dissmble & Prep 35 Otbd Seat Rib
Seems like I should rivet the outboard cargo rib to the fore and aft bulkheads and mid-fuselage bottom skin. I can't see why not. I probably will.
UPDATE: Turns out that bolt is in the way for riveting the bottom skin onto the side skin aft of the 706 bulkhead. See photo #3.
Seems like I should rivet this
And torque this bolt w/ spacer
side hole is close to bolt head
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
