RV-7A Construction Log
RV-7A
Fwd Fuselage - Rudder & Brake Pedals 5
I drilled the plastic blocks on the drill press. I used a couple angles to hold the block perpendicular. I used the #10 size bit per drawing.
Then I cut the center block in half per drawing on the band saw.
Drill the blocks
Cut the center block in half
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
