RV-7A Construction Log
RV-7A
Fwd Fuselage - Lower Longeron F 717 2
The gap was due to the lower longeron hitting the Auxillary Longeron. So I trimmed the lower longeron off to make clearance.
You also have to twist this longeron a bit to make the angle 'nest' with the weld mount and the aft end needs to be vertical to the 704 bulkhead.
Interference between longerons
Trimmed to fit (Left)
Fits snug after twisting a few degrees
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
