RV-7A Construction Log
RV-7A
Mid Fuselage - Put in Bolts & Hole Issue
I put the bolts in before riveting to help hold position of the ribs.
Turns out two ribs had their 1/4 inch bolt holes mis-located slightly because when I match drilled them I had the ribs in the wrong position.
I sent the photo to Van's Technical Support and they said, "this isn't desireable, but little that can be done now, and unlikely to cause a problem."
I hope somebody else uses this entry. Sometimes it is the mistakes that get the most pondering time.
Enlarged hole
Nut on aft side.
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
