RV-7A Construction Log
Date:  5-21-2009
Number of Hours:  1.00
Brief Description:  Aft Fuselage- Rivet together 3
I used a mirror to inspect under the j-stringers.
I had one oops rivet you can see below.
And in one place I had an enlarged hole on the shop head side. I don't remember how I got it. But I made a two hole splice and it worked like a washer across the enlarged hole. I used longer rivets and I'm sure this is a good joint. Probably overkill.
You'll also notice I primed the whole bottom skin. I'm thinking this is where any condensation would eventually end up, so primer there is probably best well spent.
Inspecting with mirror
One oops rivet
One oops rivet
One splice across enlarged hole
