RV-7A Construction Log
RV-7A
F-706 Bulkhead - Match Drill Angles
The clecoe in the two angles positioned the angles on the plate and rib. I match drilled the angles to rib and plate. I drilled the 1/4 hole also.
This cleco positions angles
Clamp drill and cleco as you go
Drill 1/4 also
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
