RV-7A Construction Log
RV-7A
F-704 Bulkhead - Fit control stick base/ mounts 1
Per plan, I fit the control column to the stick bases. Per drawing 38. My washer placement is:
Outside on pilot side (left) 2 normal washers
Outside on co-pilot side (right ) 1 normal + 1 thin washer
Inside of both sides one normal washer.
I'll save these parts per instructions, but fit them again later.
Control Column Mounts & Base
Pilot (left) side
Co-pilot (right) side
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
