Another thing I'm doing to the wing now before calling it done is installing the Dynon Roll Server to the bellcrank. Dynon sells the servor installation kit for $75 bucks so you can do part of the install with the bottom skins off.
The kit came quickly and has quality parts. You have to drill one hole in the bellcrank arm 2 inches up from the main bearing hole. The hole is size #11 for a AN-3 bolt.
