RV-7A Construction Log
RV-7A
Push Rods - Large Pushrod Bellcrank to Stick 2
Then I taped shut one end and ran some MEK inside the tube in preparation for spraying primer inside the tubes. After allowing them to dry I sprayed the primer in the tube.
Closed and ran MEK inside
Shot primer inside
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
