RV-7A Construction Log
RV-7A
Tank Prep - Drain Flange VA-112
I located and drilled the Fuel Drain Flange. I put a bolt thru the back to hold it centered over the hole. The holes are already countsunk. Easy part to work on so far.
Locate and clamp the Drain Flange
Drill Cleco as you go
Ready for final riveting.
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
