RV-7A Construction Log
Date:  11-11-2018
Number of Hours:  1.00
Brief Description:  Weight n Balance 1
Time to do weight and balance. This is the last major task before asking the FAA to come declare this airplane airworthy. Per Van's I need to weigh it with empty fuel tanks. Empty means with un-usable fuel. Right now the tanks are near full from the calibration. So I have to remove fuel.
I bought a little fuel pump from Auto Parts Store and used it to pump out as much fuel as I could.
Finally, I drained fuel from the cocks. I noticed one tank slowed down draining a little and blew into the vent tube. This fixed it. It must have been slightly plugged with dust or something.
I didn't get photos of the actual weighing. I borrowed scales from our EAA chapter.
I put the wheel pants on top of the wing and nose pant on top of engine so that every part was on.
Empty weight came in at 1195 lbs.
Empty Weight = 1195
Empty Weight = 1195
