Brief Description: Front Connector Magnatometer & ADAHRS 2
Before I screw the Magnetometer in place I need to install the ADAHRS. Previously I had made alluminum plates with threads to bolt down the ADAHRS. With a little modification, these worked well. Then I added the tube holders to the front of the ADAHRS.
The ADAHRS is for the main EFIS screen. I guess it has a built in Maganetometer. With the main EFIS screen and the D6 as back up, you can see I have two independent EFIS systems.
