With the nose pant fairly done I decided to move onto the main gear leg fairings. I need to buy the AntiSplat nose gear leg fairing and will do it after the mains.
First thing was to raise the fuselage, level it and install the main gears. I used a lot of grease to get it to slide into the hole and put in a bolt. I've got levels on the fuselage to ensure it is level.
