RV-7A Construction Log
RV-7A
Finishing Wings: Pitot Tube 5
I cut the tubes and flared the ends with AN fittings in place. When it is installed you can pull the tubing out thru the hole, attach them to pitot and push them back in leaving a loop good for accommodating any flex in the wings.
Cut pitot tubes pretty short
Flared tubes with AN #3 fittings
Installs easily with loop
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
