RV-7A Construction Log
RV-7A
Empennage Fairing 10
I cut off the material that doesn't fit with the plan to replace it using the HS as the mold. I covered the HS with black tape so the fiberglass doesn't stick.
Cut off bad material
Other side gets some stuff removed
Black tape put on HS
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
