RV-7A Construction Log
RV-7A
Rudder Bottom Plastic Tip 3
After getting the fiberglass added back on and sanded, I did get a good fit around the cable horn.
I plan to drop the tail light wire right over the top of the rear of the plastic tip and let the connector and wire lay in the bottom.
Fits now
You can see the fiberglass I added
notch for wire to enter
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
