RV-7A Construction Log
RV-7A
Horizontal Stabilizer Plastic Tip 4
I rivetted on the plastic tips with the 1/8 pulled rivets.
I'm closing up the end of the tip using foam. The foam is easy to shape and very light weight. I glued it in place with Marine expoxy.
Rivet on tip
Made foam plug
Glued in plug in place
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
