RV-7A Construction Log
RV-7A
Horizontal Stabilizer Plastic Tip 2
I use the sanding belt to smooth and trim the size of the plastic tip.
Next I drilled 3/32 pilot holes in the HS. Per drawing they should be 1.5 inches apart. That makes 4 holes per side.
Sand to final size
Drill pilot holes
1.5 inches apart
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
