RV-7A Construction Log
RV-7A
Vertical Fin Plastic Tip 4
I use expoxy to glue on the aluminum washers. They will be held by the pulled rivets. I rivetted on the tip. I also glued it on using fliberglass resin/hardner.
Glued on washers expoxy
Rivet on tip
Also glued on the tip
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
