RV-7A Construction Log
RV-7A
Elevator Plastic Tips 6
I enlarged all the holes to 1/8. Some spots on the aluminum came loose so I re-glued them.
I cut the tips to length to be flush with the lead weight.
Plans say you gotta put glue on the lead weight to attach the fiberglass tips. I will use Proseal for this one.
Attach nicely
Drilled to 1/8
Cut to length
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
