RV-7A Construction Log
Date:  5-12-2011
Number of Hours:  1.00
Brief Description:  Stick Installation 2
I spent a lot of wasted time fiddling around with the springs, because I missed reading the instructions to use safety wire. I thought the springs had to stretch from stick to electric servo motor but they don't.
After getting the springs hooked up, I re-installed the 4 little pieces of floor rib that I cut off a long time ago to allow easy access for installing the sticks.
Now these little pieces finally go on with #8 screws, washer and nut. I considered using a nutplate but drawing calls for these #8 screws and nut which I'll bet are stronger. These floor ribs constitute the wing box and this area has got to be primary structure.
Springs attach to servo with wire
Springs slightly stretched
Rib pieces on w/ #8 screws
