RV-7A Construction Log
RV-7A
Canopy Fitting 26: Finishing the fit
I removed the canopy and cut on the line delineated by the tape. I also enlarged the skin slot/hole just a little in the forward direction.
Fit is getting better.
The curve is looking smoother as it transitions from front to side.
The height above the second rivet hole #8, looks the same on both sides.
The transition into the slot looks the same on both sides.
The skin trim piece lays against the canopy just fine.
Curve is looking smooth
Height above rivet is the same
Transition into slot same on both sides
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
