RV-7A Construction Log
RV-7A
Canopy Fitting 24: Finishing the fit
The canopy fit thru the hole is improving and seems like it will work. 99% of the hole is on the front side of the slit.
I'm now using the 1/4 dremel drum sander to enlarge the hole in the forward direction.
Fit is going okay
Hole on the slit is working
I'm now using 1/4 drum to cut
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
