Brief Description: Canopy Fitting 13: One more trim off of lip
I decided I still had a little bit of that forward facing plastic on the canopy. I need to trim off about 1/16, which you can't really do. You can sand or grind it off, but cutting doesn't work.
ADVICE: Cut it in the bottom of the curvature early and don't creep up on it like I did.
Also noted my canopy seems to be cut very symetrical. It comes out at the same hole on both sides. I numbered the holes for easy reference.
